Packet Data Not Working
Hi after I use droid vpn app .. my packet data is not working anymore .. what's the problem of the packet data ? can someone please tell me how to fix it.. thanks!
Me too. But other sim like sun and globe works perfectly. Only smart or talk n text doesnt work but actually smart works perfectly before.
Should be check setting >> network >> mobile network, here you can check setting.
i am also facing problem with 2g/3g sim but when i am connect with wifi internet working properly means main point is network connectivity. if network connect high that main data pack working fine.
