Root Partition brick
I ended up messing up my sbl1 partition (after I backed it up) long story short , I now am bricked in dload mode . I can fix this easy if I could get the files needed . Which are included in the phones .cab (kdz) the problem is the files that live in the .cab are .wdb which can be extracted with lgextract in most cases . However this is not the case , lgextract crashes on my widows 7 x64 system after I attempt to run the wdb extract command 'lgextract -wdb file.wdb model.dll' with the error message of "wrong password" .I need the mbn files that are inside of the .wdb so I guess what I am saying is , if someone knows how to make lgextract work for the us780 or has the files already please give me a hand , thanks
No the phone won't turn on what so ever ... However with the files in the .wdb file I can fix it , however the program that is used to extract the .wdb crashes on my system for whatever reason ...
I see what your saying chevanlol , to be honest that's the only reason I felt it safe to reboot the dang thing lol . I did backup all partitions before hand .... Not sure that's of much help n
Nope, unless it can boot having your partitions backed up is useless lol. I don't think that the firmware that you flash inside download mode have that file either. Lol send it to lg and tell em their OTA screwed up your phone, did it once and they fixed it and sent it back free haha. That is if you're still under warranty.
Yeah that's probably the best idea .... All though lol I have a new idea to try out ... Maybe some of the generic mbn files floating around might work :)
I have a favor though . id like to compare the partition tables between the us780 , f260s and boost 870 .... If anyone has the time to post a screenshot it would be most appreciated ... Thanks
