I want to partition my sd card in order to have more internal memory available but I have a question: can I revert my sd card to a pre-partition state after I've partitioned it or will it forever be partitioned?
if you decide that you do not want your card partitioned, all you would have to do is just re-format your card. though i do not see why you would want to do that. i love my card partitioned. just keep in mind that you need a pretty fast card to do this. it is recommended that you have at least a class 4 or higher. but i would really say that you should use a class 6 or higher.
