stauren1203
Here is the rundown:
no luck with Odin or ADB. How would one improperly install drivers? I only know of one way.
Soon as I connect my phone to the PC a dialogue box comes up which says Auto Play GT-7100 which gives me options as to which files would you like to open.I just cancel
In My Computer it shows up as a Portable Device GT-7100 if I click on it I get a Card & Phone symbols along with how much Gb I have used/left If I then click on one it shows me all my folders that contain my files
My Note is just normal sim free not rooted have done nothing to the phone always works, I too have (Windows 7 64 bit)
"won't recognize" meaning when I plug my phone into my PC via USB and put the phone into MTP, my phone is not in my windows explorer. Still having this problem, but it has moved on to my home computer(Windows 7 Home Premium 64bit OS) as well. What is very weird is that if I put my phone into PTP, my computer recognizes it immediately. I am trying to root my phone so that I can flash the email app hack. I am very experienced in rooting, but I have never had such trouble getting 2 pieces of hardware to communicate.
This was very helpful! However, I need my PC to actually connect to my phone so I can root it and flash the email hack.
I have tried a total of 4 different cables.
Is your pc on a network where it is getting drive mapping from a server? I have seen flash drives not recognized because it retained a previous drive mapping from a different pc. Look under computer management to see if it is recognized there.
•Multiple other PCs recognize my phone as it is. My laptop at home (Windows 7 64 bit) as well as another PC here at work (Windows 7 32 bit)
•I have tried uninstalling and reinstalling Samsung Drivers multiple times with no success
Does anyone have any suggestions as to what I might try next?
FIXED!!!!!! I still don't know WHY this happened, but I simply went to "Devices and Printers" and my phone was seen as an "unknown Device." I then did the troubleshoot and then uninstalled the drivers from there. I unplugged my phone and plugged it back in and voila!! Everything is as it was. I'm so excited about this.
