NoMayoPlease
I have rom #2 and have installed pdroid. I want to install the pdroid patch. Can I use the pdroid patch for broken out?
Im running ROM #2 and I flashed the mod made for BO along time ago and it works fine, so yeah it works with #2. FYI, I used the mod tht had the throttle remover included. Here's the link (http://androidforums.com/showthread.php?t=579078)I have rom #2 and have installed pdroid. I want to install the pdroid patch. Can I use the pdroid patch for broken out?
nope all will be fine, the smoothscroll is actually already includedThe link for the Pdroid + Data throttle mod appears to be dead.
There is a working link for Pdroid, Smoothscroll and Data throttle removal, will that break anything in Number_Two or is it safe to flash?
so what is this pdroid thing? should i just include it in the rom..? would that be cool?nope all will be fine, the smoothscroll is actually already includedso what is this pdroid thing? should i just include it in the rom..? would that be cool?
yeah maybe ill add the patch... cant add the data removal thing though because (for the esteem) it would only work for some people but slow down data for others... so it not beneficial for everyone..PDroid can be downloaded on Google Play and it pretty much lets you to set the private data your apps are allowed to use, but unlike other permission blockers PDroid supposedly doesn't crash any apps when you deny them access to certain data.
However in order to get PDroid to actually work, you need to patch the ROM you are using it on.
I think it wouldn't hurt to patch Number_Two to work with PDroid but whether or not to include the app in the ROM I'm not sure.
I definitely want the data throttle remover included in #2 if it hasn't been included already.
yeah maybe ill add the patch... cant add the data removal thing though because (for the esteem) it would only work for some people but slow down data for others... so it not beneficial for everyone..![]()
. or if anyone can post a working link so i can patch it in myself that would be great too.
haha i never made one.. someone else did, it's loaded with a bunch of stuff in build.prop, init.d and something else.. not sure if im going to implement any of it untill i get some good feedback.. i have my own version with some more fixes but im waiting to upload untill i know if i will add anything.. plus im looking into that whole pdriod thing...Where is #2 1.7?
haha of coarse i do bro thats why your name earned a spot in the scriptThanks for still wrkn on it for us, we really do appreciate it very much. If you need any testing done I hope u knw by now u can pm me and I'll do my best to help out![]()
lol you were the only believer when i first came here hahaha.. well not ONLY, but you were the main tester for a few days LOLlol i been poking around in motion forums.. but the truth is untill you guys get an unlocked bootloader it's still kinda unsafe for me to put anything out, specially since i dont own the device i would feel extremely guilty for bricking a device LOL.. but i do have something slighty put together.. just not sure if im happy with it or not :/..Gonna have to steal him away to cook something up for my motion. Haha j/k
as for now im struggling with an sg3 rom, dedicated to gettin it working lol
You should release it man.
You could always add things or fix things later.
Does every phone come with a locked bootloader? Even our Connect running Gb?
well unless im blind im not sure i know how to port this over unless i read through hours worth of code.. the method provided in link is only if building from source.. which we cant do that successfully with any lg phone lol so i may just release what i got LOLYou should release it man.
