andygu3
Android Expert
he said, AOSP is almost stable on GB -
Not working Accelerometer (landscape)
Camera -
G-mail app -
Using it as my daily now.
What did you do when you enabled JIT.....(thought it was already enabled on .9.7......),,
so i thought he meant that .9.7 was the almost stable version of GB, of the updated version of .9.9.2, but i realize now that some of this is a type-o, & miscommunication, sorry about that, thats my bad.
can you give me a correct setup for .9.9.2, as in kernel, setcpu, autokiller, what do i need or dont need.
also what i dont understand, is theres a post in the .9.9.2 thread that says to enable JIT in aosp is not like cm6, where its just a few clicks, if you need help, ill tell you how or something along those lines, but then he says JIT is already enabled in .9.7, which im guess hes referring to .9.9.2.
idk, i guess i got lost somewhere in this conversation, but thanks for clearing things up, & hope you can led me in the correct place to get the most out of aosp, & what i need or dont need to get the most out of it.
Flash .9.9.2, then enable jit. Use the stock kernel in aospMod, his kernel is up to date with Deca. I set my overclocking at 768 max, 537 min. Use the stock launcher instead of launcherpro or adw
