pinkybrain
Member
I have 4.0.4 and this doesn't happen everytime but about 1 in 25 times I try to dial out and it does nothing BUT it calls the person correctly but I can't hear anything. I try right back and it works fine. Thoughts?
This is a 4.0.4 bug I've see many reports of. I don't really know any fix yet.
Do you think it will be fixed or should I try going back to a different version? Would that help?
I could have written this post! I talked to Samsung, they were NO help. I talked to Family Mobile, they hung up on me originally. The local T-Mobile store told me to ask for a new SIM card, since these phones require a different card? Family Mobile said that wasn't the problem, we'll just replace the phone! (Seems like trying the SIM card would be cheaper)Mine has been doing the same thing, Family Mobile is replacing the phone so we will see if it helps. From the reading I have done here it looks like its a software problem (ICS) more than a hardware problem.
