godsdragon
I just bought an LG Optimus V. I love it and the reviews were great. I am wondering if I got a lemon. It heats up too much while downloading apps, charging and other... hmm... Please help!
Oh darn, really? I noticed mine gets hot quickly especially if I'm ωatching νideos while it is charging. Right noω I'νe been on the internet ωhile my ρhone is charging for almost 2 hrs, and the temρ hasn't reach 100MacFett said:I think you both may have bad batteries.
I use Juice Defender right now to monitor my apps and save my battery. Does a pretty good job so far I think.
Not sure who told you to fully drain the batter, but you never want to fully drain a lithium ion battery.
There are several threads in the OV forum with replies from a member with a good deal of knowledge on the subject.
happy
camper!The only time my phone gets warm is when it's searching for wif for a good bit of timei. I have wifi at home and at work so it's not unusual for me to leave it on routinely. But if I spend the evening away from either place the phone starts to get warm. I turn off the wifi and it's back to normal temperature pretty quickly. I do think it wise to have returned the phone.
Agreed! Here's one of `em. I bookmark the thread because there's valuable info.
http://androidforums.com/lg-optimus-v/359348-battery-life.html#post2888501
Good article! Got anymore? Not trying to give you a hard time, just looking for add'l verification. Judging by the single BU link, charging often does seem the way to go. Only minus (if one would consider it such...ymmv) is having to constantly plug in. My lifestyle is more "on-the-go" and frequent connection to an outlet is not a viable option.
Table 2 was interesting. If you take it at face value, and assume a once-per-day charge schedule, discharging to 50% every time before recharging yields a battery life of more than 4 years. Does anyone even keep the same phone for that long? Even doing a 100% discharge every time, you still get almost 1.5 yrs on a battery.
Im new to these smartphones and thought I would have to replace the batteries every year or so anyway.
Anyway, thanks for the opinion backed up by some decent science rather than a mere opinion. Cheers!![]()
Syav, how are you getting Greek characters in your posts?
Or you can use a battery monitor such as battery life.You can check the temp of your battery when you think it is hot. Dial #*#*4636*#*# and when the menu pops up, click "battery information."
. I got worried once and checked, and it turned out my hands were just cold--the battery wasn't really that hot.
