Root Phone is slow....
bidzer
Member
Hey All,
My triumph is 2 years old and has been through the ROM ringer a lot :-) For some reason now, any rom i install seems sluggish. Everything from Froyo, CM, and PA. I've formatted the sdcard thinking it may be corrupt or fragmented but no improvement.
The roms run off of internal memory correct? Is there a way to format the internal memory of the triumph to essentially start clean? Maybe this is a way of my Triumph saying I need an upgrade :-)
Thanks,
Bidzer
did you remember to redo your over-clocking settings, cause if you have been over-clocking then go back to the stock speed it will seem slow
That's usually the first thing on the list when I throw a new rom on :) I run at 1.5Ghz. It's weird. My wireless throughput on this device is horrible compared any other wireless G connection. Thanks for the reply.
Hey All,
Thanks,
Bidzer
When you flash most of the ROMs it formats /system and when you do the factory reset you format /data and /cache. Have you tried a known good ROM? That would be my first suggestion. And don't put any other apps on it until you get a chance to test it out.
I don't think overclocking to 1.5 ghz is necessary. Flash a MOD called Crossbreeder. You can find it in on XDA. It'll boost your phone's performance. For a smooth ROM, I recommend either CM9 20130415 or PA June25 tester.
I'll give this mod a shot after doing some research on it. Thanks for the info.
I'm going to install VM-Revamp and see how performance is. Thanks for responding.
