Okay, without the vibration, it isn't an app crashing. BACKside is very stable (I use it). When did you last flash your phone? Jerry posted an update for the ROM yesterday. Do you notice any kind of slow down, or does it happen without any warning at all?the cm7 backside IHO version, and nothing happen before it freezes and reboots. It just freezes at any time. I use the stock browser and dolphin too.
Good call, I didn't think about that one.Have you run the fix permission option in the recovery?
Do you have flash installed, and what speed do you have the CPU set to?
The fix permission can take up to 10 to 12 minutes. When your watching your phone it seems like twice that.ok, here is the update: When I tried to fix permission, it says fixing permission... and takes for ever, so I took out the battery to reboot the phone, guess it is not working either. Then I tried to use xscope as a different browser,it didnt work, I mean it freezes around some where and reboot. At this point, I think I would try what Andy said, see what will happen,and will give you guys update. Thank you all for the help, hope the problem can be solved.
Agreed, when I do it I put my phone down and do something else. It tends to help when your impatient.The fix permission can take up to 10 to 12 minutes. When your watching your phone it seems like twice that.
