Glad to here, it really is a stable rom.
We have sorta come to a conclusion that the best cpu settings are 480 min and 768 max with the interactive governor. But every phone is different.
Leave the set on boot box unchecked, start at 768 then keep raising your max cpu one setting at a time until your phone reboots, then come down two settings, that's where you should set your max cpu, then check the set on boot box.
