Help Phone not turning on? Please Help!
lilcdkey
Another problem with my captivate...
I tried to software update my phone and it said that the phone needed to restart so I let it restart. Now the phone wont turn back on! What should i do?!
It doesnt even seem like my computer is recognizing it, when i plug it in :(
If this was the official 2.1 update through AT&T that you tried to download Over the Air, you might be in for a warranty replacement.
The OTA update probably hard bricked your phone...
Well I used Odin to return it to factory settings. Then I tried to software update and now it won't turn on. Will me using Odin void my warranty?
