Help phone screen doesnt turn on..
arasto3
I've been facing a problem with the phone recently where the screen/image doesn't work. I can turn it on but the backlight turns on but nothing shows up. I can press the buttons and feel the phone vibrate and the touch works but i don't know what im pressing. Anyone else seem to be facing the same problem or know what i can do to fix it?
If this is happening frequently then I'd suggest returning it under warranty. Tbh it sounds like a faulty display, which should be covered.
