Phone starting issues
viperlocc
Member
Turned on the phone this morning, it loaded fine. It then rebooted and sits at the HTC screen. I didnt even get a chance to do anything lol.
Cyanogen nightly 9/22, kernal #14
Did that a couple times. Rebooted into recov, and did a restore from an earlier date. That still didnt work. Gonna try one more restore to a near factory setting.
If that dont work...what next?
got it back to near stock and it works....
wonder what the hiccup was? gonna download the new nightly/kernal and see what that does.
New nightly, newest kernal, and newest gapps installed. Seems to be running fine now.
Dont know what that was about, never had any issues before like that.
If you ever run into this problem again, there's a simple solution instead of nandroid
First, always make sure you have a nightly on your SD Card.
Second, if this happens again and you get stuck on the white htc boot screen, pull battery and boot into recovery
Wipe Davlik cache and cache
Flash the nightly you have on your sd card
Then reboot phone, simple as that;)
