Help Phone stuck on mag 113 screen
Aries324
Hello..i tried to install android on my hd2 by using the method listed on autotradeking.com..everything was going well till i got to the mag 113 rom and the phone disconnected and would not allow me to do the nand rom and it also will not reconnect to my pc...i also noticed that my pc does not have outlook..could that be the reason the android install failed?:confused: I also tried the windows reinstall method posted but when i do the boot loader method it does not read the sd and my phone says serial at the bottom instead of usb..somebody..ANYBODY..PLEASE HELP!!!!:eek:
ok, you need to make sure you have every thing set up so that Windows Mobile Active Sync is working (when it had WM).
If that is true, then when you hit the option to Flash USB, it will not show connected until you launch the NAF.exe (as Admin) (or whatever exe the ROM tells you to use).
Try those steps and see if that helps ya out.
dude go to xda developers and have a look on there allso there are some good tutorials on youtube, just installed nand on my HD2 no problems every thing working top notch sorry to tell you that do some research you will get it in the end
