The other night my wife's phone started complaining that it was "Low on space", "Internal phone storage is getting low".
When we clicked on the notification it took us to the App manager and there were 0 bytes free in the Device memory.
This was particularly odd because she only has 15 apps installed, whereas I have 190 installed (including almost all the same apps she has) and she has very few media files.
So I uninstalled an app, to free up a few MB -- and within about two seconds there were 0 bytes free again!
I repeated this a few more times, and every time the newly-created space would disappear within seconds.
I did a bit of Googling and the only hint I could find of a problem was some reports of a Wifi issue where log files would fill up storage. This made some sense as that same day I'd been playing with a different Wifi router and used the same network name but a different password, so it wouldn't be able to connect -- but that could just be a coincidence.
Unfortunately there seemed to be no way to recover from this problem unless you had a rooted phone other than to do a factory reset -- which would suck, because one game she's spent countless hours playing (Smurf's Village) doesn't use Google Backup Services to store progress.
Another odd symptom was that the battery was slowly going flat even while on the charger. That indicates that something was using a lot of CPU even though nothing was running. The back of the phone was also really hot near the camera, like when the CPU is very busy.
So eventually we shut it down and rebooted it the next day. I deleted another app and this time the memory stayed free. (I was afraid to shut it down the night before in case it couldn't boot with no storage space, but eventually we had no choice because the battery went flat.)
So now I have a phone that supposedly has some free memory (19 MB free at the moment in "Device memory", nearly 11 GB in "USB storage").
But if I try to move an app to "SD card" it says "Failed to move application: Not enough memory". I thought that I was able to do that before I installed an SD card in my phone and that it actually moved it to the 11 GB of "USB storage" that the phone has, but her phone is refusing to move anything.
If I try to install an app -- I wanted to try "Disk Usage" to see if the place where the unwanted data ended up was visible -- it downloads OK but then says:
"Error: Application cannot be installed in the default install location."
This is despite "Disk Usage" being only 150 KB and the internal storage now having 19 MB free.
So I'm stuck -- I cannot move anything (apart from media files) from the internal storage to the 11 GB of free "USB storage" and I cannot install anything.
Can anyone help?
The ideal outcome would be fixing the phone while keeping the "Smurf's Village" save file and not having to root it. I have the Android SDK but not sure if it will help.
Thanks,
Jason.
Edit: Sorry, should have mentioned that she's still running stock 2.3.3, Baseband version is I9100XXKE7. I don't think it's been updated since we bought it in December.
Can anyone help?
Thanks,
Jason.
