Help Phone won't boot up. HELP.
TeamTJ
Member
My phone won't turn on. Whenever I plug it into a charger, a picture comes one prompting me to put the back to my phone on. Well, the back is already on. I have tried taking it off and putting a new one in, I have tried taking the battery/sd card out for a few minutes then putting everything back together, but I still get the same animation picture.
Any suggestions?
This is an indication of a bad battery. If you know anyone else with an Optimus S you can try their battery to provide troubleshooting.
That problem will follow whatever device (Optimus S) you put the battery in, indicating that the problem is with that battery.
Open up a adb terminal with your phone, plug it into your computer, type in "adb shell" no quotes and see if it recognizes it
I'm new to the S forum. Trying to help were I can, making sure I give no phone specific advice.
I'm sure the proper code is: cd adb devices,then the enter key.
Wow, that's embarrassing! And I'm the one who's really supposed to be paying close attention to every little detail. Good eye.
Maybe I need some grandpa glasses.
