Root phone wont boot up
I tried flashing back to an older rom I used before, but this time it said there was an error and wouldnt work. I tryed doing a restore and that didnt work either. Now when i try to reboot, it just gets stuck on the 3 skateboarders. And when i try to go into recovery it just shows the triangle with an exclamation point, instead of the old menu I used to have. Is it fixable or did I brick it?
what rom did you flash back to?
sounds like you removed your recovery mode somehow.
follow the instructions to flash it back. use the instructions on the how to root your phone tutorial
yup. your starting over.
what rom did you flash? you clearly screwed up pretty bad, what did you use and what were you attempting to do?
pretty sure the main thing i used was just the regular 2.1 with root. i flashed the kaosfroyo earlier just to check it out, then tried to flash aloysius snow that i already flashed before with no problems, but this time it didnt work. so i tried to do a nand restore of my regular setup but its not working either
not sure how to start over since i cant turn my phone on all the way to mount the sd card to place PB00IMG.zip. And if i try to skip to the recovery section i keep getting "-exec '/system/bin/sh' failed: Not a directory <20>-"
What recovery are you using? Clock work recovery causes these problems and we haven't been tfigure it out and usually have to get a new phone, there is a few cases on the xda forums. If you don't have the clock recovery try charging your phone all the way seen a couple cases where battery charge was the issue
Yea that sounds like the problem then. So how should i go about getting a new phone? I have the protection plan but since it was rooted would they not allow me to do that? Or should i say it was lost/stolen?
that would be best.
or take it in and show them that its just not booting. that could get you a new one too
