Root Phone won't boot
apavolka
I tried installing Gingerbread about 6 times downloading it from a different mirror each time. Each time it was aborted and out of nowhere, My phone got stuck at the M. I tried booting into Moto recovery and sort of got it and I ended up doing a battery pull. Now my phone won't boot at all. It doesn't show that it is charging while it is plugged in. I've seen this before many times but can't find the threads anymore and I'm not sure if I can SBF right now.
SBF failed?
and yet again, my phone wont boot at all... greeeeaaaat.
Edit: damn it... My phone ended up dying. Recharging... again. I give for tonight. Ill try again tomorrow. I just need some way to listen to my music tomorrow...
i think you need rsd lite 4.8?
isnt yours lower or something?
its been awhile, so someone step in if im wrong. my set up usually looks like this (with the thing from happy holidays from team black hat):
check the numbers on build and rsd lite version.
then i use this once im rooted:
2.3.340_kernel_updater.zip
its 2.3.340 kernal updater
at least thats how i remember doing it....
You should just use 2.3.340 full sbf...are you still using the 2.3.320 full sbf? Or is that just a screenshot you had on hand?
If you can get it to boot and have an SD card reader I can send you a zip for 2.3 and that should get your phone up and running again.
Good luck
memmory serves me this is what i use with the update .zip file to 2.3.340 after root i posted....
but if theres somethng else out there he should use, glad yo usaid something
It just eliminates a step, either way you end up at the same place ;)
