ceabbott2
Ok tried to do EPST and forgot I was on Warm Z(can't do the epst on Warm Z). So I factory reset data wipe, then caulkins format all, then restored a nandroid (whoops I forgot I flashed the all radios zip and my nandroid had the old 1.77 NOT 1.90). I'm guessing that is how I screwed it up! But now I get the Amon Ra picture of the phone with the green arrows in a circle formation. Tried to take battery out and hold volume down and power to go into recovery but it takes me to the same Amon Ra screen. Any ideas what I can do? I'm dead in the water. AT THE FIRE STATION ALMOST EVERY SITE IS BLOCKED BY THE CITY! IF anyone has an answer can you email me at ceabbott@cityofhendersonky.org
Thanks Guys/Gals
PS Do I need to take micro sd card out reformat and place my backup from my laptop on the micro sd card?
Both clock work and Amon Ra recoveries on on the sd card I just renamed them.
Thanks Guys/Gals
To explain my earlier post after I did the no brain epst fix on Warm Z I went into recovery to flash a stock sense back up and then I saw the old caulkins all radio flash and I thought sure why not (after I did a factory reset and caulkins format all) Then before I rebooted I flashed the nandroid of Warm Z and whallah Amon Ra screen with arrows. What an idiot!
Seriously if you want you can email me if you have time tommorrow. I'll be awake looking in here since EVERYTHING else is blocked by the city.
