Help picasa problems on droid x
chrlswltrs
Extreme Android User
I just got my droid x this morning. I have everything set up and have added my picasa account, but when i look in my gallery there is nothing. On my droid all of my picasa albums showed up in my gallery which i loved. Did i do something wrong? Or does the x just not sync properly with picasa?
My albums and photos showed up easily the first time today. Then later on it just sat there trying to connect. Give it a couple days to settle down and make sure your logging in correctly.You have to imagine... this is a hot new google endorsed phone so tons of us gmail junkies are all testing out the features at the same time.
It doesn't look like the DX Gallery syncs with Picasa like the Droid Gallery does. It's unfortunate, but as far as I can tell the only way to get DX device pics up to Picasa is manually uploading them individually your Picasa account (which can be added under Settings>Accounts).
PicPush is an app that worked perfectly to autoupload device pics to a designated Picasa album, but it worked perfectly on my Droid Incredible -- it doesn't work at all on my new DX.
Anyone have any other ideas?
Pm me your email address, I will send you the apk for the gallery from the Droid. I 7se it on my X and it works great, the same as it did on the original Droid. I'll email it tomorrow.
