Had this tab for about a year for my son, suddenly won't boot, stops with the word "android" on the screen. As far as I can tell it's a Pillbox7 A13 based tab, but there's no make or model on it. Have tried factory reset by holding either vol + or vol - while powering on but nothing seems to happen, it doesn't even come on to the android logos. I then have to press and hold the power button for 10 seconds before I can then switch it on again. I popped it open yesterday and disconnected the battery for a while but that made no difference. This morning I installed LiveSuit on my lappy and plugged in a usb cable but I got the exact same results as above when I held the vol +/- buttons as I plugged in the cable.
Is there anything else I can try, perhaps with a microSD card? Or can anyone suggest anything else to try, or is it dead?
