Help Pix for Wallpaper
DonDuke
In an attempt to set a pix as wallpaper, the phone keeps cropping to fit. I have photoshopped it to be the right orientation, etc. But I seem to be making the pic too big. I saved it at "low" quality to make it small. Does anyone have the specs as to the size (in pixels) it needs to be to fit into the wallpaper window?
Thanks!
Thanks!
960x800 i believe
I had same problem on my droid x. I used a photo editing program to change the size of the picture to a width of 460 pixels. Emailed it to myself and then loaded it from my picture files. There is also a droid app called dodol Wallpaper that can help you chose orentation. They have some pictures that you can download to see aspect ratio on the photo.
Hope this help some. Doc
