You could get mp3's at a higher bitrate? Generally you'll likely be downloading music at between 128 - 190kbps. If you're able to find something around 254kbps, you'll notice the difference.
Wave files use up a lot of space, I believe they are the biggest audio files except from the super professional ones. Your best bet is to use FLAC files. They are better quality than mp3s and are not too big. I think a lot of third party players support them, such as poweramp
