i restored with the stock unrooted backup and relocked my boot leader ,s-on and stock recovery and now im downloading 4.4.3 update as the backup restore was of 4.4.2 so i was hoping that the update will solve my problem .i am not sure what you mean. You wont have root access if you have returned to stock. Does your bootloader screen say locked ?
Have you checked the thread for returning to stock. Is busybox and SU deleted and is it your own stock backup ?
Actually the 4.4.3 ota will install over completely stock but rooted 4.4.2, on Verizon anyway.
Again, I can only speak for the Verizon version but you will lose root taking the OTA from 4.4.2 to 4.4.3, the only way to get root back is to be s-off.
You should never go from s-off back to s-on and then take a OTA unless you plan on never being able to root again. Luckily Sunshine can still s-off most M8's on 4.4.3.
