I'm having a little issue I'm hoping someone can help me with
I just rooted my HTC EVO 4G using the revolutionary method
Everything went fine. Rooted perfectly. Installed ROM Manager, downloaded cm7
I then went and downloaded the tiamat kernel and installed it from zip
However, I never applied cm7 before doing this. Only installed
The issue is I'm stuck in clockworkmod recovery....
I installed from zip, rebooted. When I reboot, it goes straight back to clockworkmod recovery
How would I reboot my phone so I could install cm7 and then reinstall the kernel?
Would factory reset help? or would that wipe my sd card? (My concern is losing superuser and having to root again?)
Any feedback would be amazing! Thanks in advance
