dchamilton
Member
I
Edit: On second thought, you might even like http://androidforums.com/galaxy-pre...432614-rom-gb-2-3-6-ctmod-3-3-03-17-12-a.html with http://androidforums.com/galaxy-prevail-all-things-root/429740-kernel-gb-koumakernel-2-4-a.html and enable "Mount SD-EXT as /data partition"
Can the updated kernel be put into ctmod?
Also, is there a link on how to do the "Mount SD-EXT as /data partition"?
Thanks
I was actually leaning towards ctmod 3.3, but saw that koumakernel 2.4 just came out. Can the updated kernel be put into ctmod?
# mount ext4 /dev/block/mmcblk0p2 /data rw noatime nosuid nodev barrier=0 data=writeback nobh nodiratime noauto_da_alloc
