basscommander
Worked like a charm!!!! Mucho thanks duder! You saved me from an ass whoopin' from my wife, lol!
Not that I've found.
If you don't wipe all 3 it'll boot loop... I found that out the hard way the first time I tried to restore my nandroid.
I have never wiped doing a nandroid restore....Weird
Really!?!? Man, it NEVER works for me unless I wipe.
What Recovery Image are you using?
It looks like all the programs that I HAD on my phone when I did the back up are no longer installed on my phone. But the little white paper and gear icons are still there, even though the programs aren't, so at least I can see which ones I had, so that I can go redownload them lol.
Heroc 1.6.2
I have to hold vol down and press power to get to a "fastboot" menu where I choose recovery from 3 options, just to get to my rec. menu. I don't know of anyone else that happens to.
I always boot into recovery via adb. I have only NOT done it via adb 1 time. I find it to always work doing so from adb![]()
I have used the kitchen, and never had a problem. I can always get to recovery doing the vol down, press power thing, but it took me a little bit to figure it out the first time it happened to me. It started when I flashed 2.1.1, before that I could hold home, press power and boom, recovery menu.
Btw, you need to update your info below avatar and display proudly that you are running 2.1.2 now![]()
Yes, I NEED to be sure I am going to keep it...
I will soon. How much free space do you have? Mine reads 20-23 mb, and still runs ok, But I'm curious where others stand with it...
