Root Please help me with root!
Tyler
Member
I have followed Jonamerica's guide and searched for hours on help but I can't seem to find it.
Currently I have been unable to get unrevoked to notice my device is plugged in. I have enabled USB debugging.
Please any help would be greatful!
In the unrevoked download bundle, there's an html file. Did you open that and follow the procedure for loading and installing the unrevoked driver?
Yea I did all that. I did it twice too, still not changing anything:(
The only things I felt confused about were:
-installing SDK to c drive
-"Make sure the phone is fully booted, connected to the computer via USB, and USB debugging is on" what does fully booted mean?
It means booted up. Did you follow all the steps in the unrEVOked driver install page? public:windows_hboot_driver_install [RootWiki]
Did you uninstall HTC sync and PDAnet?
so pdanet causes a problem?
i am currently in the same boat. Currently Unrevoked cannot see my device. So I need to uninstall pdanet?
Also HTC Sync. Is that something you have in your phone already? cause I have never downloaded htc sync from the market.
HTC sync is something for your computer that you would have had to download and install yourself. I don't have a windows computer, but I believe PDANet causes conflicts with drivers, so uninstall that. Let me know if you still have issues after removing those.
put it this way people... uninstall everything that is related to your phone but what they give you.... everything else causes problems
I've never downloaded pdanet or htc sync. Only thing is doubletwist but I completely disabled that.
And I looked under device manager and it said the hboot thing was there.
When I'm in the bootloader screen do I have to go anywhere? I currently just leave it on the main screen
I think ill try It on my Xp laptop. Do u think that will help?
Thanks for the help guys!
What OS are you running right now? If you have a mac or a friend that has a mac, it's really simple if you can't get it to work on a windows computer.
I'm using Vista. Friend has a MAC but would I have to use it if I wanted to add or change anything to it that required root ?
