Root Please help - overheating & quick battery drain
stanfna
forgive me if this has been covered. I did a search and did not really find what I was looking for.
here is the deal...
I have an Inc. with CM7. I put my phone on the charger at night. I take it off the charger around 7am. by 11am I am at 25% battery remaining and the phone is hot to the touch. I typically don't do more than check facebook and play words with freinds while eating breakfast (maybe 10 minutes of use). i thought the battery was going bad. so i bought a new SEIDIO battery. I am getting the same results.
so my questions are as follows....
1) what could be causing this? i know the first thing you will say is an app running in the background. I have used Advanced Task Killer to see what is running and kill all the things that i do not need. (i don't have it set to autokill) so if it is an app, i can't figure out which it is.
2) can I take it back to the Verizon store to try to have it replaced? since i am ROOTED and running CM7, will they give me a hard time?
what should i do?
Thanks everyone!
You may just be best off wiping and reflashing the rom. But before you do that, try an app called OS Monitor from the market. IMO, it does a much better job showing app activity than most task killers or system monitoring apps.
thanks for the idea...
i may try that.
what about getting a new phone? will i need to put the stock ROM back on? i am only 2 months away from my contract renewal.
Idk are you planning on trading it in or something? I don't know what the rules are on that situation, if they require a certain condition.
If its under warrenty and you want to take it to VZW, you would have to un-root and reload the stock rom first. They won't touch the phone with CM7 on it (unless you get EXTREMELY lucky with the tech you hit).
I would try a factory reset first. of even take a nandroid bkup and re-install CM7. (run it for a few days mostly stock with only SAFE needed apps) and see if it still does it.
