SteveWHamilton
Hello, everyone, this is my first post on these forums. It seems that i might have bricked my Samsung Galaxy Prevail. First, i downloaded the latest version of ShabbyMod to my phone and unzipped it. Then I downloaded ROM Manager/Clockwork. after starting this app i first tried the option to fix file system errors, as i found that i've been recieving alot of force-close messages as of late. then i hit the backup option, it prompted me to install Clockwork Recovery. so i hit that option, and noticed that the galaxy prevail wasnt on the phones list. so i just chose any random entry and it downloaded a profile or something (or whatever its called).
then i hit the Backup option again, confimed, and then my phone screen immediately went black. i waited about half an hour, assuming that it was backing up the stock ROM and would power on soon. 3 hours later, still nothing. i have tried removing and reinserting the battery, as well as holding Volume Up plus Power button (recovery mode), still nothing it wont power on. Also, when i try to plug into a wall outlet it still wont power on. I checked my MicroSD by inserting it into my laptop, all my files and app info, etc are still there. I would also like to note that i was rooted using ADB method before installing ROM Manager, for over 3 months. I am certain of this because ROM Manager requested root permissions before starting.
So basically, what i need to know is, am i bricked? regardless of whether i am or not, is there a way to fix this? can i format my phone's ROM/harddrive from my laptop and reinstall that way, either with the stock ROM or ShabbyMod?
Also, can my phone run CyanogenMod?
Well, if anyone can help, plz reply soon. Thanks in advance!
