Root Please Help!!!! root problem
Hi.I'm new to this.ill get right to the point.my entire system on my rooted infuse turned small.small everything.keypad.letters.notification bar.I had installed rom toolbox and changed entire font to "defused" font and it worked perfectly but I decided to switch to a different font and all of a sudden when it rebooted it everything turned small.please help.first time root user
Do not worry minor problem I'm sure it can be fixed. Haven't installed any fonts yet but Im guessing you should be able to fix it somehow. However I can provide some help in that next time this happens, do a nandroid backup before you change anything valuable on ur phone. If u don't know what a nandroid backup is, its just a way to save the state of your phone so if u mess it up you can restore it. For more info I recommend you google "infuse nandroid backup" and if u need any help anywhere in the process just ask here. As for the font, I'm sure someone here with more knowledge will figure out the remedy. Gl ;)
Are you sure you did not accidentslly chsnge the lcd density?
of it is font it is as simple as changing it again
