Root Please help stuck at 10.1 boot screen
XAL2
Please help I am stuck at the Cyanogenmod 10.1 boot screen after installing a custom Flash screen that was posted for our phones. I would boot into the bootloader but I cant because the file is still there. Please helpWhat can I do to fix this?
no big deal.This has happened to me after flashing a splash screen while on Cyanogen. im not sure why it happens though. What you need to do is pull the card. Put it into PC or even another spare phone. And erase that file. Then flash a backup or whatever. Thats your only fix
I did the same thing and it went into a boot loop but I went and wiped dalvic and cache and it worked for me. Just take the SD card out go into recovery wipe both caches and try and reboot but do that without the SD card in the phone
I will try that and I will report back.
If wiping cache and dalvik doesnt work I will try this.
If you need to get to bootloader you just need to remove the file from the sd card. Either use a card reader or another phone to get the file off.
Also in the future there is a tool called aroma file manager. If it's on your sd card you can remove sd card, boot into bootloader, plug into wall charger, remove battery, insert sd card, return battery, then go into recovery and flash aroma file manager. Then you can remove the PG86IMG file from your sd card without a computer. But you would already have to have the file manager.
