AndyOpie150
<strong> <a href="http://androidforums.com/optimus
The one on the sd card is fine. Once you install it you no longer need it or the recovery on the sd card. The ROM and Gapps are the same way. Once anything is installed from a sd card the sd card version is no longer needed.That includs apk's as well.wait, i've changed the permissions of the flash_image in /system/bin to 755, but not the downloaded one in my external sd card.
so should i change the permissions of the flash image in my sd card to 755, and then run commands with chmod 755 flash_image?
What your changing is the permissions on the one installed. That is the one that matters.
