Root Please help unrooting!
Is he sure that he doesnt have Amon Ra and the S-on zips on the card because I did that when i was trying to flash the sprint lovers rom and since they had the same name the sprint lovers rom had a 2 behind it which recovery didnt recognize. Just trying to help....
ok so i completely forgot about this. it has to do with how you originally flashed the evo. if you used the unrevoked forever to root or unrevoked3. if you used unrevoked forever then the s-on tool will get s-on (sometimes you may need to run it a few times to get s-off).
however, if you used unrevoked3 then try the PC36IMG file. it may sat s-off after running the s-on tool, but after you run the PC36IMG file, it should say s-on.
so you were right a few posts ago. sorry about that. so i would try running unrevokd s-on tool one more time then do the PC36IMG file.
