Root Please help with Roms
The problem is your memory isnt being read correctly which in turn is affected by connecting to the pc.
Try this first. Pull the SD card, with the phone on and put it back in and up in the status bar, see if it says "reading" or "Ready" after you insert it. Then report back
ok problem.... i cant do that while my phone is on. i have an extended battery and it dosent allom me to puch the sd card back in..... and i dont have a regular one .... :vollkommenauf:
No problem. Just turn the phone off. Pull it. Put it back in. And boot back up. Check settings and see what it says then. Hopefully it will be mounted and you can connect to your PC.
Yea Lets Hope no need to get no negativity here and let the victim think its all over :)
No no no. Worst case scenario is a 15 minute fix at most.
At least now we know from the SD results that it is a phone issue and not a computer issue. ;)
when it turnes on it said internal scan then it did media scan and it said 100 % you may now wright/ read on SD card. but i checked in settings and every thing is still the same. and nothing happend when connecting to computer
LOL forgot to say no Homo Part LOL u Might wanna edit and at the end put no homo LOL i like u tooo NO HOMO ;) :D
I REFUSE to utter the words or type the words "No homo".
Im not going to speak my feelings about that phrase, I might get banned. lol
LOL ok then am just sayin am not homo so i shouldnt get banned and srry if i didnt anything bad Mod's
I Changed it to a phrase I like better. ;)
No you wont get banned for saying it, I was talking about what I personally think about that awful phrase and whoever came up with it. They should be slapped. Over and over again.
Just Changed Both Of them
