Okay so I'm about to flash my first rom. I performed Calkulin's_FORMAT_ALL \ but when I attempt to reboot it takes me to the screen with the bootloader.... and now I'm lost....... Any help is greatly appreciated....
ok it has been awhile since i was on clockworck mod, but there should be a usb toggle option. i just don't remember. can you list the options you have if you haven't found it yet?
mount/ system
mount/ data
unmount/ cache
mount/ sd card
mount/ sd-ext
format boot
format system
format data
format cache
format sd card
format sd ext
mount usb storage
