hi all i have been reading the forum for a while and have just about decided to get a hero.
i had a play with one in the 3 store on sat and loved it.
im just a bit concerned that it is a difficult phone to use i have never had a smartphone before, iv used a iphone my wife has one but from what iv read the andoid isnt as straight forward to use, i am quite techie so i have no worries about learning to use it but dont want to spend all my time doing it if you know what i mean.
also i quite like the white on and was thinking about going with orange but theyt dont seem to do it so any suggestions where to get one or a pic of the graphite on in the flesh if anone has one (havent had chance to get to orange store) and does it come with all the orange branded sh!t that you normally get when buying a orange phone.
im currently with o2 and would like to saty with them but cant seem to find if they will bw releasing it.
sorry for the long post but hopefully you guys will be able to asnswer my queastions cheers.
. cheers.
A device doesn't cease being "great" just because it's no longer current. so long as it still meets the user's requirements.
