Diego1593
So i found this website to build a recovery image or clockwormod wondering if it may work
Recovery Builder
Recovery Builder
Someone pointed out this recovery builder before, only problem is that it doesn't support locked bootloaders.
What about touchscreen 2ndinit recovery? 0.o
Another epic sig by sammyzPost #4 xD
Your location is epic too
Back on topic, yea, unless you know how to make a 2nd init recovery, this is almost useless (sorry OP) and if you know how to make a 2nd init recovery, you would also know how to build CWM recovery yourself. It might be possible to use that to build CWM Touch if the bootloader is unlocked or if you need that recovery image to build 2nd init recovery, but I don't build recoveries, just somewhat of an idea of how they are built.
