pls help.rooted, but didnt do a full wipe.
caloyzki
hello, i just rooted my phone but i didnt do any full wipe before rooting my phone. can i still do a full wipe and root my phone again? pls help/
There's no need to do a full wipe when rooting, a full wipe only needs to be done when changing roms. I would recommend booting into recovery mode and clearing cache and dalvik (in advanced). Then just reboot and you should be good.
ty for the response. i am planning to change my roms. is it better to do a full wipe?
Its always better to do a full wipe when changing roms. It stops the chance of things from the old ROM interfering with the new.
Boot into recovery, and the option is in the main menu.
hi i wanna do a nandroid back up first before doing a full wipe, but
HOW come when i do a nandroid back up i go to backup and restore and hit back up it says "Can't mount backup path" what am i gonna do?
Is this from recovery or the CWM app? Whichever, try the alternative.
not from the CWM app. i turned off my phone and press voulume up + home button + switch button.
now i went to the CWM app and click the reboot, and from there samething happen. "cant mount backup path"
omg, maybe my phone bricked already? i cannot do nandroid backup anymore.
It's not 'bricked' as it still works. You've got a problem with your internal storage partition (/sdcard) though, as it's obviously not being recognised. Do you have an external SD card installed too?
that is the problem. dont have any external SD as of the moment? is there any way that i can go back to un-root phone (like how i bought it) and then i am gonna do the root again. maybe that is the only way to be fixed?
Sure, just flash the stock firmware back with Odin.
sir, how and where i can get the stock firmware? thank you.
just to let u know, this is the only one that i put on my phone thru ODIN and nothing else.
CF-Root-SGS2_XX_XEO_LPQ-PROPER-v5.4-CWM5.zip
and after i flashed that to ODIN i get the CWM, and SU icons, and i install titanium backup and i back up all my files, but when i backup nandroid thru recpvery mode that is the one that is giving me a problem it wont backup. ty.
Am I correct in thinking you have the M250K? If you do and used cfroot to root that could be your problem. If you do have the M250K try flashing this custom kernel with Odin
http://gokhanmoral.desean.net/siyahkernel/v2.6/Siyah-v2.6.13-kor.tar
nope the M250K is from my brother.
i have this I9100UHLPE.
how can i un-root my phone to go back the way i bought my phone? ty because i cannot backup from nandroid. i want to go back to the original settings and everything and then i am gonna root again. ty hope u can help me.
Official, stock firmware, for I9100UHLPE, Android 4.0.3, here.
omg. ty again ironass. i really owe u a lot. and shotgun,slug and everyboody for helping us here. u guys really help a lot of people on this site.
i am gonna run this to odin and it will go back to un-root my phone?
because after doing that i am gonna root it again.hopefully i am not gonna get error message by doing backup from nandroid.
No need to thank me caloyzki... just send me a box of aspirin.
I know I've said it before, (in at least 4 other posts to you), please read everything carefully and thoroughly... here is my motto...
"Flash in haste... repent at leisure!" :argh:
have you looked in the .7z file?
I dont know exactly what you downloaded, but there may well be a .tar file in there
