BH_MAN
Android Expert
Holy Jeebus! Is that on standby?! How heavily are you using it?
Just mainly Weather Widget & Few Calls here & there...
BH! Found a BIG bug. The Gpaps, Phone, Dialer, and other mass FCs that I've gotten since the start of the ntwiz 1.6 rooms seems to ONLY HAPPEN IN VIB! I never use sound because of the classroom/workplace, and today working from home with a mess of phone errors, I turned the volume on
Hey BHMAN are you moving to a different site I noticed it on the 1.6 galaxy sticky you might of mention your could move?![]()
There is a bug where the phone will not sleep after being charged. Solution, reboot phone each time you disconnect your power cable or charge the phone while turned off.
I have a Macbook.. Can I still root my Behold 2? If so, are the directions the same?
HELP!!!! i am having some issues with rom from time to time.
when using the dial pad, sometimes it get stuck then say forceclose, it dos it with something else too i forgot tho. is there a fix for this?
I have a Macbook Pro. I was able to root using Terminal but had to use just a little bit different instructions for navigating around folders. But pretty much the same. In order to flash, though, you will need Windows and the program called Odin. You can virtualize it and work with it that way.
try flashing take 5 over here(Port) Behold 2 1.6 ( No Twiz w/ Busybox & Rooted Kernel ) - AndroidSPIN Forums and bhman is not updating any of his roms here move to the new forum
I'm having trouble using the terminal.. Would you or anyone else care to provide like, the EXACT coding? lol
/Users/(Your_Mac_Username)/(Then the directory of your Android SDK)/tools/adb
/Users/omarquinones/android/tools/adb
Ok. First make sure you download the Android SDK so you have adb. Here is what I do to get into adb:
For instance I have my Android SDK folder in my home directory. Here is my code:
From there you can follow the other tutorial which assumes that your on Windows. Basically instead of using the cd commands to navigate folders, you just provide the paths to the different folders in your commands...
Hope this makes sense.
So I got to the part where it lists the devices attached, but it doesn't show mine. After seeing that, I tried to follow the directions to install my device's drivers, but ran into the same problem with the MacOSX and Windows stuff.
Hey! Newbie here. I'd just like to ask how to remove the Home++. I want the default screen back. Thanks!![]()
this rom keeps crashing every time i am using the dialpad. it did it on warheads and now it still doing it on take5. i am uninstalling
Really sounds like a Phone issue, than a Rom issue..
Idk though, problem posted I can get the 2 phone's I have to produce...
Starting to think it's App's that messing with the install, also.... Please remember this 1.6 was never Released & was still beta if you will...
Have to take the bad with the good..
