couldnt find any info here so i am writing this to raise your awareness
both official ICS rom XXLPY and ZSLPF released, as well as leaked ICS beta roms for galaxy note including N7000, I717, and I9220, contain a bug that may brick your phone. lots of ppl suffered already so pls be alerted
the bricks and damages are not happening each time you do a wipe or disk format on your phone. no one knows when it will happen
so at the moment, i suggest u to stick with gb and not upgrade to ics until the problem is solved
however, if you r brave enough or think this msg is totally rubbish, it's up to u but no flaming pls and i wont argue with u and respect your decision
read the links below for more details:
Galaxy Note ICS XXLPY phone bricks - issues - http://ykkfive.blogspot.com/2012/05/xxlpy-phone-brick-issues-and-advice.html
Galaxy Note ICS XXLPY phone bricks - advice - http://ykkfive.blogspot.com/2012/05/xxlpy-phone-brick-issues-and-advice_16.html
Galaxy Note official ICS ZSLPF and XXLPY confirmed unsafe - http://ykkfive.blogspot.com/2012/05/galaxy-note-official-ics-zslpf-and.html
good luck
good luck
