I get better than that stock.It shouldnt be necessary to do this in order to get good battery life but....root that sucker, get a custom rom + kernel, and setup some setcpu profiles. Yesterday after 12 hours I still had 50% battery in a 3g area. Sounds good to me!
Honestly after taking off the batter door on this TB a few times I'm not very confident in it's ability to withstand very many off-n-ons.
Really piss poor design. Nothing more than having to pop tabs to get it off those plastic tab nubs are going to start wearing down and breaking off in no time.
Can't believe they didn't just put a slide/pull down type latch thing on there. Coming from a BB Tour and while it had lots of problems the battery door made sense.
Why they didn't put some kind of latch/spring type mechanism on here. Well I know why - shave a penny here, spend a penny there. Can't have it all. But constantly removing/reinstalling the battery door on a TB I'm getting the feeling is not a good long term idea.
I completely agree- I've taken my back off twice and broke a nail the 3rd time and thought, well this was a terrible idea. It's also pushed me towards wanting the extended battery and not just back up's because it doesn't seem as easy to swap in and out like my BB was.
(Slash- I kinda miss my bb- but I'm giving the TB a full trial period)
I doubt it , there just isn't enough space for a bigger battery . 1600mah is as big as it's going to get . I refuse to put the hump on the back of my phone. But as with the EVO and Incredible which the extended batteries were awful huge humps as well. Some hong Kong comapnies came out with Generic extended batteries with a non hump , while the design of the Thunderbolt will limit what they can do I bet there better then the back HTC made for there extended battery
Once this phone has a good undervolted kernal you'll be able to get 20-40hrs easily out of the stock battery I can almost guarentee it
Is it normal for my phone to drop about 10% battery every hour when it is just sitting in my pocket?
You can't expect a straight answer to this can you? There are tons of variables at play. What apps do you have running in the background? Are you in a 3g or 4g network? How is the signal strength? is gps on or off? is wifi on or off? etc etc.
I see from a lot of the posts on here that people recommend getting JuiceDefender. Now is that in lue of not getting task Killer? or do ya'll get both?
