Post your Android Desktop
I like the app/widget on the last page to show the photos. What app/widget is that?
Whenever I try using custom icons for launcher pro, they are always extremely small in the dock. Is there a setting somewhere to make them bigger?
I even took the same icon, and re-sized it and put the original one next to it on the phone and they were still the same size... Switching back and forth between TWLauncher and Launcher Pro, the icons are clearly bigger on TW..
Using a Samsung Vibrant.
Thanks!
Thanks!
LP automatically resizes icons in the dock. There are a bunch of posts about people creating a dock with the icon images already in it. Then put a completely transparent over it.
edit: sorry if it sounds like I'm coming off as a dick. Long day
Not at all.. Thank you for the help! :)
I will search to see how to do that. Hopefully it isn't too hard.
Not much of a change from my last layout.
All relevant info:
Cyanogen Tazz v8 w/ collin_ph battery tweak
signals23's modified LauncherPro
Dock Icons where a quick creation of my own
Main Screen:
Left Screen:
Right Screen 1:
Right Screen 2:
All you need to do is simply create your icons within one image sized at 480x84 pixels.
You can of course make the background transparent.
The icons you use within this image will not scale downwards.
You'll need to make sure that they are positioned in the right place (lower) so that the notification circles for unread email, sms etc do not cover your icons.
Doing it this way does of course mean that when you scroll horizontally through the other 2 docks, the images you have used as icons will be behind the other two 'dock' screens.
Use LauncherPro Settings > Appearance to use your custom dock as the dock image.
As suggested in the previous post use Transparent icons at 72x72 pixels to overlay your own dock icons with links to the relevant shortcuts etc.
Hope this helps.
How does everyone make everything transparent?
I bought launcher pro plus.
Is that all I need?
Or some modification somewhere?
I wanna make all my widgets transparent, like my Extended Controls app etc.
This is such a beautiful setup! If that's the smooth calendar widget, how did you get the icon to look like that? And if that's the last call widget, how did you hide the phone number? Thanks!
What music widget is this here? It looks really nice.
And lastly, how did you get your clock (digital clock widget?) to look like that? The one I found on the market has a gradient background instead of this I think.
Thanks a lot!
Music Widget is '3' from market.
