Post Your Home Screen Captures
GO SPURS
widgets used
- Launcher Pro
- Make Your Clock
- Beautiful Widgets - flat carved weather skin
- Minimalistic Text - battery bar
Can this be used without a rooted Optimus?
Mine's not rooted, so, sort of... I made a font folder on my card with Astro, but I've only used them with that clock widget (mClock), which lets you browse through your phone 'til find your downloaded fonts. There might be other widgets which let you do the same, but I'm not sure. Can't use them as system fonts or anything like that without rooting (that I know of).
Howd you get your lockscreen changed from default on Optimus? Do tell.
Using Widget Locker lockscreen app.
WidgetLocker Lockscreen - Android app on AppBrain
Works okay - did a test, and it does work on Optimus without the use of an alternative home launcher. Not sure how it plays with launchers other than the one I'm using: Go Launcher EX.
Since I'm running it with Go Launcher EX (and not ADW, which pairs with widgetlocker according to the developer), there isn't syncing of my Go launcher ex theme icons to the lock screen. With Widget Locker, you have to use ADWNotifiers to get phone, email, call updates on the lockscreen - but again, I'm not using ADW, so no dice. Annoying, since I'm trying to eradicate the status bar in general. And I hear ADW is too slow to use at the present time.
I am considering switching to Launcher Pro and seeing if the Widget Locker will work with that launcher.
