Post your home screen!!
The clock widget doesn't...but the alarm widget does...
Granted, that widget is so buggy I've once or twice been tempted to soak my phone in Raid. Every 2-3 days it would just decide to stop updating and I had to delete and re-add the blank widget, and then re-add my alarms to the widget to get it working again.:mad:
It does, but that requires two widgets where only one Is really necessary - I try to keep my main screen uncluttered so that I don't go into instant visual overload when I turn on the screen :)
And yes, the Samsung alarm is QUITE buggy. I was using a Fancy Widgets clock that linked directly to the alarm, but every few days my alarms would reset from the (loud and jarring) songs I chose, to one of the twinkling New Age offerings that comes on the phone and stands not a chance of awakening me. Timely has its own set of alarm functions rather than using the stock set. We'll see if it works more consistently!
Well, to be fair there is a clock in the status bar, so a clock widget is more redundant than an alarm widget :p
Look at my screenshots, if we were to compete for cleanest home screen it would be, at best, a draw ;)
Okay, I'll give you redundant. ... but definitely more necessary when I haven't put on my glasses yet ;)
My other screens are considerably less "minimalist" and would probably give you hives - but I'm one of those extremely visual-memory people, and I can get to every icon on every screen without needing to look. And that's the ultimate joy of Android, isn't it? Setting it all up the way that works best for you :)
what rom/theme is that? its gorgeous!
The lock screen is also a part of holo?
I think you were asking about Octa's lock screen, while dmajors's "holo" was referring to his own screenshot.
Octa's looks a LOT like my CM10, which is based on ICS, but I dont think I could make CM10 look like that. So my guess is it's either an ICS theme, or Octa never upgraded to JB.
Edit: CM10 lock screen attached.
On the topic of alarm clocks and widgets. I use Alarm Clock Plus and its great, fantastic even. Use it on the tablet and phone. I'll post a homescreen later.
One screen, one phone :p I like one-screen devices, even with my 180+ apps on my N10. Here ya go. Kudos if you can tell me what kind 'o engine that is, or who made it.
Lock Screen
Home Screen
Pre-post edit: Which of their engines it is since manufacturer is listed on it >_> So is the number of cylinders so forget the whole kudos thing, I'm a moron XP
Well, seeing how my Vikings have crapped out this season, time to switch over to Hockey. Showing my "Wild" side ;)
I like my home screen to be basically informational.
Gonna have to try it I haven't yet Still using the Flashable Stock Zip
& Have it Setup how I like it & Knowing That LTE isn't Counted Yet against Data used On it Is Great! Did have to use disable services from play store to Stob the Over the Air Update but for now I am fine with it ,
Hoping for more Devs will Get Involved in This Device but with S3 & S5 Soon to be on Virgin Mobile their Probably won't be
But Still Hoping
But Still Hoping
There was an ota for us ?
