Post your home screen!!
Guess we're getting cut back to 2g speed now after 2.5 gigs of data is used
And there is an update if you just open your phone as in brand new or if you flash that zip its before the Update I think not Sure because I took the Steps to disable ota Updates before so I get no notifications figuring I can always flash a new ROM with updates once devs here have chance to pick apart what we'd want vs Not
As a rule of thumb I always consider ota Usually Bad once Rooted & To let them D/L or Install usually makes Bricked Devices or Bootloops , So Since I am not a Dev I Use Disable services From Play store Under System & Framework's & Disable the SystemUpdate Services ( Learned that Trick from My LG F3 By Virgin ) the Team their
I haven't seen an update since mg5.
And I don't think we're getting throttled yet, just clogged network. Check your speed at like 3am, 4g speed. And I hope they don't throttle us to 2g, that's 1X. And its only supposed to go down to 3g speed from 4g.
Tried Androguy1991 Script from the Virgin F3 on this Device ( Seems too work ) using his Script & Script manager
On the Victory
I'm using the launcher that came with conquest and the kitkat theme( Google experience launcher). And then I am using an xposed module called tinted status bar. This was the only launcher that works with it but also works with a few apps.
