Post your home screens
Here's mine, I only had the captivate for a week so it's a good simple start :)
What is the battery meter you are using on the lower right corner? I like that one.
Thanks. :)
I've only had my captivate for four days now, its my first smartphone and I'm loving it! I recently rooted it, and finally got done with this windows 7 phone-like theme. I think its looking pretty cool. First one is my home screen, and the next two are to the left and right of the home screen.
...I recently rooted it, and finally got done with this windows 7 phone-like theme. I think its looking pretty cool...
SkateEmerica:
Looks good.
Don't forget to check the "Auto-Fit Items" under LaucherPro's "Homescreen Settings". It will even out the spaces between widgets.
Stalked here for a while. Thought I'd post a couple of my screen. Thanks for all your help.
Where did you get the SIM Memory Status Widget? Or maybe I should say "What is it?"
Its called system info widget. It $.99 and there are plently other things you can display. The only negative is that it will only show internal 2GB storage and external SD but not the internal SD.
How do you change font color, scroll bar colors...even the switchpro icons. Im so tired of this white
Switchpro - just add new widget and there is option to choose colour for both the icon and the indicator as well as setting transparency for the icons and the background.
Font Colour - Which font are you asking for here?
Scroll Bar Colour - Do you mean the notification bar colour? if so you need to use ultimate online kitchen to modify your framework-res.apk then you can apply it as an update in CWM boot menu. Details here - http://forum.xda-developers.com/showthread.php?t=775970 . I used it to change my notification bar to solid black and add a % battery remaining text inside the battery icon. You can also make the notification bar transparent, however it will not appear transparent if you are using launcherpro for the home launcher, as that doesn't support transparency in the bar.
Almost there, you can see what im going for. Im real proud of the Emulator icons I made in Photoshop though
Homescreen
Screen 2 (Not finished)
i have photos that are 960x800 that i'm trying to set as my background and my captivate wants to crop the image....? what gives?
oops...scratch that...i had no idea you could resize the crop box by dragging...very cool.
I've been rocking TW as my main launcher lately. I'm seriously tired (read, lazy) of redoing LauncherPro every time I re-flash a ROM.
Here's my three home screens. First time using desktop visualiser. Still a work in progress.
Lol actually how do I post pictures? I use the shoot me app and they are saves on my sd card.
I've been rocking TW as my main launcher lately.I'm seriously tired (read, lazy) of redoing LauncherPro every time I re-flash a ROM.
You know LauncherPro has a backup option that, when restored, puts all your widgets and settings back as they were before? Might want to check that out.
Mine:
Status bar with old font (I have it hidden 99% of the time):
SimiClock
Beautiful Widgets Weather 1x1 (Simiclock's weather icons are a little bonkers)
Red Soul theme (from here; Perception 4 ROM only atm)
Comfortaa 1.003 font (from here; best Captivate font imo)
Battstatt
LauncherPro (transparent Plus widgets from here; must-have for any LP Plus user)
Signal Strength Widget
SwitchPro
