Post your home screens
So glad I'm finally able to post screencaps thanks to an app BigCat8 posted in another topic. I'm only using 3 of the 7 screens for now. I can't think what else I need to add.
Oh and the phone is on Android 2.2 and non-rooted.
Try out a home replacement app like Launcher Pro or ADW Launcher so you can customize even more!
How did you get the honeycomb icons to work with launcher pro.
They're probably just PNG files, then there's a number of ways to use them. LP when you choose icon, you can simply pick a graphic file (using the gallery to browse/choose).
that does look cool 4n6. i like those icons. and they were on iconspedia??? ill have to look harder i guess...lol
here is what i have come up with that i think im gonna stick with for a while.
the wallpaper is of great american ballpark last year when the reds hosted the phillies.
Sweet! I was at that game. Stupid Phillies.
ok you ready for this one..lol had a friend at ZEDGE.net make this wallpaper for me. icons are from iconspedia. and i went a little crazy with the RED icons...lmao.
ok quick question. the apps icon that was default with ADW launcher how do i get it back if i want or where is those icons stored?
http://
This was taken with. The screenshot right from my phone without hooking up to the PC.
Trying the all black wallpaper idea.seeing if it helps my battery
A work in progress
Just a few stats:
Go Launcher (free in market)
Wood theme Icons (go launcher theme, free in market)
Pixel Ants (pay version, tho i forget if you can freely change colors in the free version or not)
I'm aiming for a wood theme and "termites" eating the wood, I only have a "concept" home page for now.
Watchdog is in your status bar. What app is Watchdog alerting you to?
nothing thats just it. the only thing that ever really sows up is the android OS.
tbh i dont htin watchdog is all that good. at least the free one.. maybe im missing something with it.???
Uninstall Battery Booster. It's a Task Killer in disguise and can cause some probs. The Watchdog Alert tab will alert you to overactive apps. You can decide to kill the app manually if it's in the alerts tab. No need to kill anything in the CPU tab.
when i kill these, they just pop right back up??
A lot looks to be OS / AT&T / Samsung apps, so they are written to load/reload. For the rest:
Watchdog - duh...
Dual Clock - a widget you have running maybe? If so it'll restart next time the phone goes to post info to the widget. If not/never try killing it thru more stock/built-in means, you might be able to teach the phone to not preload it.
Antivirus - if it auto scans apps on installs or at a time interval then you'll see it, tho it might stay dead till the next instance it wants to scan.
Dialer - from what I've seen, if you successfully kill it you can't make or receive calls.
BattStatt - widget so same as Dual Clock
BatteryBooster - It will re-spawn when it sees fit, or possibly a widget.
Facebook - using the widget I assume, else it might be set to auto/background sync so it will restart itself.
Media Hub - do you actually use it? Else follow what I said for not using Dual Clock, I did and I never see it running anymore.
But, lets not let this stray too far from the main topic.
Gorgeous theme, tell me how to get it along with clock please?
Hi and thanks its just a wallpaper and custom dock that I put together along with some widgets. Plus I am using the Launcherpro app for my phone.
here is the wallpaper its in this set that you can download
Black Background Set by *iAmFreeman on deviantART
The weather widget is Beautiful Widgets then I just downloaded the clock skin.
The other widgets is the PowerControl Widget and the other widget is called "Widgetsoid"
The dock can be found in the launcherpro forums
(its alot of pages lol sorry its in there somewhere)....but lots of awesome docks can be found there
LauncherPro Forum • View topic - Share your custom dock backgrounds!
Swapped from LauncherPro to ADW Launcher EX ... and from SwitchPro Widget to Widgetsoid.
Home screen, as it normally looks...
Home screen, with the "hidden" dock visible...
Lock screen...
Yep. That's in the ADW options. I love having the dock hidden, it gives me more screen real estate.
Think I'm going to end up attacking executive assistant, working on changing the icons so my lock screen looks a bit more uniform.
