saps
Extreme Android User
Nice app drawerThanks for the clock widget. I've actually kept this for a couple days.
Nice app drawer![]()
what lockscreen are you using to get the slider all the way down on the bottom. I've used lock 2.0 but the slider sits about a half an inch up from the bottom
Ain't it awesome.
For now. Still looking for a news widget. What is yours Rimzy
You need to uninstall voodoo first as outside jt's rom most rom builders recommend not using voodoo with their rom but I suppose it might work. But yeah stupidfast only comes in nonvoodoo. FWIW, jt's 11/15 does have a voodoo flavor and its as fast as geeknik's kernel. So maybe try that try the 11/15 voodoo and then try SuperDark on top if it does take you'll have to odin restore and then you can easily grab stupidfast and superdark; so either way cannot lose just one might be easier than the otherLoving that Super Dark Rom! What do I need to do to go from Rooted w/Voodo to StupidFast w/SuperDark????
Nice thats a very seasonal theme, perfect for this time of year or if you're from Holland
Is everyone using WidgetLocker for putting widgets on the lock screen? Are there others? Is that the best one?
Lockscreen
What's the weather widget you have there?
